Phillips is similar to pozidrive - a cross. The difference is Phillips is designed to slip out, the pozi isn't. They are close, but no quite the same. Generally, speaking, Jaguar used Pozi. A pozi screw will have small hash harks at 45 degrees to the main recesses. The wing mirror screws are a great example.
Go to the local parts store? even the chain stores will have a good quality set of them, for about the same money. You don't have to wait on shipping, and if one breaks. You can usually get a replacement. Off Ebay, you're usually just out of Luck. I'm curious as to what Stores, you guy's have in the UK. We have Auto Zone, Orielly's, Advance, Pep Boy's, just to name a few. They carry most all car, and truck parts, and have tools and supplies as well.
Although I never realized, I've already got loads of these TORX bits that came with sets of drills that I've bought in the past, though this will be the first time that I've ever needed one
This T40 TORX in a Socket Wrench was the ideal tool to remove the set screws in the Vacuum Module
This T40 TORX Bit and Socket Wrench was ideal to remove the Set Screws in the Vacuum Module
