Still smoking,oil burn after valve cover gasket replacement.
Old 06-15-2018, 05:01 PM
vincent661983's Avatar
Default Still smoking,oil burn after valve cover gasket replacement.
Location is directly below the coolant level reservoir.
Please help
Old 06-15-2018, 05:19 PM
harvest14's Avatar
I had a leak in that spot on a previous X308 that could NOT be fixed. I used three different brand gaskets and even resorted to RTV, it STILL leaked.
Eventually I got another valve cover from the salvage yard. That fixed the leak.
Same exact spot as yours though.
Old 06-16-2018, 12:36 PM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
The most likely problem is a crack around the bolt hole on the cam cover that opens up when tightened down. Another possibility is the part load breather is plugged at the cam cover orifice and will build pressure on the left bank cam cover. Try pulling the part load breather hose and running a drill bit held by a pair of pliers to clean out the carbon buildup.
bgr5722
12-30-2017 05:49 PM
David Bedoya
01-15-2017 04:12 PM
harryjbrice
Diesel variants - All models
01-10-2014 07:43 AM
unionjack
01-14-2011 09:21 PM
Quick Reply: Still smoking,oil burn after valve cover gasket replacement.
