What did you do to or buy for your XJ-S/XJS today?
Old 06-03-2018, 03:48 PM
Steve M's Avatar
Received 2,996 Likes on 1,691 Posts
Come on Steve, where exactly (and I do not mean where did you lie down)?
Bought a trolley jack.
Jacked the car up.
Crawled under the car and had a lie down.
Released the trolley jack.
May as well, it's frigging killing me anyway!
  #982
Old 06-03-2018, 03:58 PM
Steve M's Avatar
Further to the question, back end of left side passenger floorpan, behind the seat.
There is a tube that runs through to take the hand brake cable from the lever through the rear bulkhead; depending on market one side or the other should be plugged.
Mine wasn't so over the years the rear wheel had been throwing water through the tube and the rot set in to such an extent that the jacking point got pushed up in to the floor.
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-20180423_091045.jpg
Greg in France (06-04-2018)
  #983
Old 06-03-2018, 04:13 PM
Steve M's Avatar
But, on a brighter side, I was so pissed off that I did some trawling through the t'interweb, looking for something to cheer me up and came across these little beauties.
Unluckily I was literally walking out the door to go away for the weekend when postie turned up so didn't get to see them until this afternoon.
They are rarer than hen's teeth found in rocking horse poop and I was pant-wettingly excited to see them and (for a change!) I wasn't disappointed.
One of them came in a sealed Jaguar bag wrapped in original Jaguar brown paper; I'll be listing that separately later.
Behold and marvel at my (quite expensive) luck:
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-20180603_181551.jpg
The following 2 users liked this post by Steve M:
89 Jacobra (06-04-2018), Greg in France (06-04-2018)
  #984
Old 06-04-2018, 12:47 AM
Greg in France's Avatar
Received 9,269 Likes on 5,444 Posts
Classic rust spot there, and just as likely to have rotted inside to the out. If you feel keen enough, remove the rear seat and you should find a hole in the outer lower corner of the vertical seat panel (the one just behind your shins if you were sitting in the back seat). Some cars have a rubbishy seat belt slider rod in this position. Anyway, get some AquaSteel and using a garden sprayer spray it in the cavity through this hole each side. Wait a day and do the same with an aerosol of wax (Bilt Hamber's Dynax S-50 seems to be the best I have found).
Just in case you get bored with driving it, something else to do.
LOVE the new badges, I am a sucker for that too!
  #985
Old 06-06-2018, 04:56 AM
Steve M's Avatar
Do you reckon that an XJS could tow this?
https://www.trinitymarine.co.uk/shop...nching-system/
  #986
Old 06-06-2018, 10:44 AM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
amazingly easy with amazing results... a pleasure job... pure engine tuning stuff - FINALLY...
removed, cleaned throttle bodies AND reset all linkage,,, installed new throttle bushings. they were just FLOATING before - no throttle bushings or even pieces to speak of in there. For now, the plastic ones that I intend to replace with brass - or something. Potentiometer set at .33-.34
she runs completely differently now. idles perfect,,, quiet,,, with jus the slightest hesitation - like when stopped at a light and then hitting the gas to go. the the throttle rotor is moving before the linkage and flaps are. I think I may start a thread asking for help to solve that. any suggestions?
ANY SOURCES ON THROTTLE RETURN SPRINGS - cant find any anywhere!?
  #987
Old 06-06-2018, 02:33 PM
These guys have them, JJJ. I have had some from them, very efficient and helpful, and in the USA!
  #988
Old 06-06-2018, 03:21 PM
JayJagJay's Avatar
Hello Greg --- Who? I don't see a link...
  #989
Old 06-06-2018, 04:55 PM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
JJJ, can you tell us more about cleaning the throttle bodies? I am wondering if that would help my car's vibrations at idle.
  #990
Old 06-07-2018, 12:56 AM
XKs Unlimited - Classic and Modern Jaguar Auto Parts Specialists since 1973
I definitely posted the link, another internet demon?
  #991
Old 06-07-2018, 08:56 AM
JayJagJay's Avatar
Hey Greg... This is what I got,,, broken heart-ed, again. Yesterday, after digging and digging, I found the spring at Terry's. It was odd and I hope I ordered the right thing. In the image it is clear that number 8 is the spring... Then, in the itemization, there are two(2) number "8's"... I was - broken heart-ed - clicking on the first "8" and to find discontinued. Then, clicked on the second and BAM! I ordered four(4)... I really really hope I have receive the right thing. If not, I'm tempted to go to some hardware stores and matching it up...
HELLO SomeDay. I am terrible! One is, I have so much to do on this machine, and so so little time - working FT and until recently a FT student - that I have been HORRIBLE about offering back to the forum and sharing my stuff. Honestly, I feel guilty about it in a way. I take take take and I don't like that I'm not offering anything. Another part O that, os that in many ways these jobs are my first rodeo.... I am focused on the job and getting it right I kinda don't have the mental energy to be doing the documenting.. What i might do is go and add it to the the one with "alternative fuel lines" thread. Or, start a new one... I need to get better at documenting... Yours is a good question. Let me get to it. Honestly, it was a pretty straight forward thing. And, KIRBY PALM and older threads,,,, guided me. It's worth the hours. Basically, just undo everything, and do it all over as guided by the Kirby and the teachers here. It works
Some Day, Some Day (06-21-2018)
  #992
Old 06-07-2018, 02:42 PM
JJJ
If we are talking about the same spring, you only need 2, one each side. NO 8 in this diagram C45981
  #993
Old 06-07-2018, 03:20 PM
JayJagJay's Avatar
Hey GiF... Thank you!
Got ya! I ordered four(4) because they were so hard to find,,, I almost ordered ten(10). At Terry's they were like $4 bucks each,,, I think. I understand I'll only need two(2)... I went to take the four(4) and did order.
They called me today to tell me that they DON'T have them, they have been DC'd, and they sent me a refund. Unless I can find a source, I think I will just have to go to the HW store and try to match something up... Length and Resistance. Don't want to but what option do I have. Thankfully, I still have the old
  #994
Old 06-08-2018, 02:00 AM
JJJ, get them from the guys in California I posted.
  #995
Old 06-08-2018, 03:16 AM
Daim's Avatar
Be careful, they are actually two different springs! I was gob smacked but yeah, two different ones. Different length etc.
  #996
Old 06-08-2018, 04:14 AM
Officially yes, but I got mine from XK, both the same and they were fine.
  #997
Old 06-08-2018, 06:59 AM
JayJagJay's Avatar
Gooooood Morning GiF...
Unless I'm missing something - a link to a supplier that HAS the part available didn't show up in your comment... Could be a forum/server malfunction
I looked at the link you DID provide,,, and it says "part no longer available" or something like that. And,,, it looks like it lists/suggests or describes two(2) on each side in the link,,, while the pic ya'd sent in thread shows one(1)....
What gives,,, lol???
Maaaan, I so so appreciate YOU...
  #998
Old 06-08-2018, 09:13 AM
get them on the telephone (xk unlimited) and ask them. I know they have them made.
I found them on the site OK, here they are. And there are only two, one each side.
Jaguar Throttle Spring, Multi-App Return Spring, Stainless - CO-14366SS
  #999
Old 06-09-2018, 01:50 AM
Edelweiss's Avatar
How much does it weigh? If less than two tons, sure, why not?
  #1000
Old 06-18-2018, 11:59 PM
VancouverXJ6's Avatar
Rear Diff/Cage renewal complete with KYB shocks, uprated cage mounts, heavyduty poly bushings and new brakes plus a ghetto auxillary fan toggle because my thermal switch is dysfunctional.
Will mount switch in behind ignition on a blank dash faceplate out of the way when I have time. For now this should help with my gridlock overheat issue.
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
