Service manual PDF.
A while back someone provided a link to a full service manual in pdf format which I have downloaded.
It seems to have everything in it but it's a bit hard to find things.
I'm beginning to research a big repair and once I finally found it I noticed that none of the highlighted links are working?
I have a read only copy of Adobe so do I need to purchase an upgrade?
WO these links that allow you to jump to the procedure being reference it's very hard to use effectively. Maybe that's why it was free?![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Thanks for any help.
Bob S.
Bob S.
Roger Simpson (02-04-2022)
Here is a link to the workshop manual:
http://www.jagrepair.com/images/Auto...M-Workshop.pdf
Use the 'search' function in Adobe Acrobat Reader to find what you want. Remember this is a 14 year old pdf and functionality with newer readers will not be the best and yes the links will not work. I think they did work with the Adobe readers built for Windows XP, but that was over 10 years ago. Obvioulsy Jaguar have no need to update the file as the s-type is an obsolete model.
You will also need the electrical guide:
http://www.jagrepair.com/images/Auto...cal-2005on.pdf
Also here is a link to the official on-line parts cattalogue:
https://www.jaguarclassicparts.com/uk/s-type-parts
You will find the TSB's and other usefull downloads here:
Mellow
Mellow
S-Type Owner (02-20-2023)
Bob S.
Bob S.
I have a 2004. Jaguar xkr. The service manuals would be very helpful.
James
Welcome. I see that the above is your first post. It might be helpful to post your inquiry in the correct forum for your model Jaguar; it can be found here:
XK8 / XKR ( X100 ) - Jaguar Forums - Jaguar Enthusiasts Forum
Also, when you find time, please post the expected "introduction" in the New Members forum. It is to your advantage to do so as this gets you additional forum privileges. The forum can be found here:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
clubairth1
05-28-2011 05:02 PM
