Headrest monitors X350
Hi guys..... just acquired a very pristine 2006 X350 sovereign with all the bells and whistles.
At the moment everything seems in working order with the exception of both the headrest monitors.
There is power to the DVD unit in the boot and it appears in working order but the screens are blank.
Could it be something as simple as a blown fuse or is there a more ominous/ expensive issue going on here...
Appreciate any suggestions.
Your goal should be to use the "Left" and 'Right" buttons along with "video select" to get the console display to say DVD at the left and right ends. If you can get to that and your still have no issue then it may be a hardware or fuse issue.
According to the Workshop Manual,
Fuse No 20: 5 Amp protects in the Front Power Distribution Box protects Rear entertainment control panel (accessory supply)
Fuse No 30: 10 Amp fuse in the Front Power Distribution Box protects Rear entertainment control panel/AV selector/DVD player (battery supply)
If these are OK, there are lengthy pinpoint tests detailed for troubleshooting no display on either rear screen.
Colm O (06-12-2020)
So just a quick update. I tried all the 'easy fixes' over the weekend, checked the fuses , disconnected the battery etc but still no joy.
I have found a specialist ICE shop just a couple of kilometres from my office here in central Dublin which will be the next port of call. Thanks for all the feedback and will keep in touch on the issue.
Headrest monitor won't turn on
I haven't x350 XJR it has all the DVD players and screens but for some reason both to be a screens will not turn on, I have put a DVD in and can hear it playing but it will not come on the screens as the screens will not turn on please help, I am also pretty sure all this interior and the headrest and the DVD player has come out of another car but I bought it like this as it has got the two plus two seater arrangements
watson6505
11-28-2019 12:03 PM
