Jaguar F-Type Engine Ticking/Exhaust Squeal
Context: I have a 2014 Jaguar F-Type supercharged V6 with 80,000 miles. I got. For $32k at a local dealership on February 28, and the car has had a few check engine lights come on already which I already sealed with *the purge valve was replaced*
Problem 1.) Engine Ticking.
I have this very annoying sound coming from the engine bay that is very noticeable when at a full stop. I can’t really hear it while driving. It’s especially noticeable at a cold start. Any ideas of what it could be?
Problem 2.) Exhaust Squeal & Screeching
At cold start the engine has this terrible squealing sound followed by a second screech. Once the engine/exhaust gets warm both sounds disappear.
but while running errands & driving normal the sound is very loud. Especially when accelerating, letting go of the accelerator or braking. I will record a cold start and upload it below . As well as the ticking
Problem 2 could be the exhaust valves opening and closing, they can become loud if un-lubricated, which is more likely on an earlier model F-Type. It would make sense on startup as the vehicle starts with the valves open then closes them as vacuum pressure builds.
A squealing sound could also be the supercharger drive belt, the recommended interval for replacement is I believe 96k or 6 years, which for your car would mean it is overdue.
Do these sounds occur at a certain RPM?
I had a ticking sound at startup on a truck a year or two ago, eventually traced it back to a manifold leak that would go away once the vehicle came up to temp.
No experience with this on the f type, but if you're noticing ticking that's obnoxious at cold start and becomes less noticeable drive, that's probably where I'd start. Good luck.
tergitkerd (09-09-2024)
The active exhaust valves are external to the muffler. The one time I looked at the valves, I didn’t see how to lubricate them.
https://www.dropbox.com/scl/fi/9295g...byy3flocp&dl=0
Carbuff2 (09-09-2024)
Most likely the ticking sound is the idler pulley. It is a known issue and there was a technical service bulletin: https://static.nhtsa.gov/odi/tsbs/20...95351-1020.pdf
See repair instructions: https://static.nhtsa.gov/odi/tsbs/20...18147-9999.pdf
I had mine (2017 V6) replaced under warranty and the sound was eliminated. I only noticed it at idle, just as you described. If the pulley fails it's bad, so be sure to take care of it: https://www.jaguarforums.com/forum/f...pulley-191513/
I would argue that the injectors sound like a tap, not a tick. The idler pulley ticking sound is very obvious at idle, from inside the car with the windows and doors shut where ordinarily you cannot hear any tapping or ticking. Like I said, better to get it checked out before it ruins the rest of the belt drive.
So I've confirmed it is my valves squeaking. Is copper grease a semi permanent solution? I've heard it usually requires a full replacement of the back box but that feels like a temporary solution as well since the design seems to be the problem.
They are also Titanium/Inconel and massively expensive as a result.
Last but not least the exhaust valves may be different.
