Limp mode.. caused by left turns?
Hey everyone, this is a continuation of my 4 month saga with Restricted Performance mode, but I thought how we are able to replicate it was interesting enough for it's own thread.
Long story short, by accelerating and turning left my 2016 Jaguar F-Type R goes into "Restricted Performance" mode. Sometimes this causes it to drive somewhat normally and still get up to ~50mph, other times it has been bad enough to not get about 9mph and idle very roughly. We have replaced the:
- Throttle Body
- Accelerator Pedal
- ECM
- BCM
- Battery
Yeah we changed the TPS along with the TB. Codes are still:
Appreciate the reply as I’m really grasping at straws here ha.
- P06A7: Engine Management System Performance.
- P2127: Throttle/Pedal Position Sensor/Switch 'E' Circuit Low Input.
- P0122: Throttle/Pedal Position Sensor/Switch 'A' Circuit Low Input.
- P0221: Throttle/Pedal Position Sensor/Switch 'B' Circuit Range/Performance.
- P2135: Throttle/Pedal Position Sensor/Switch 'A' / 'B' Voltage Correlation.
- P0237: Turbocharger/Supercharger Boost Sensor 'A' Circuit Low.
Seems like a bad connection in the wiring or ground.
Some good info here:
https://autoservicecosts.com/obd2-codes/p06a7/
Sorry about the ads.
Does your vehicle have a supercharger or turbocharger?
Excuse my thread resurreciton. First, did you ever find the cause? My 2017 F Type R now has the same issue. I'm getting the "Restriced Performance" message fairly regularly now, and I get the P2127 code only. I've replaced the accelerator pedal, throttle body, battery, and am in the process of reflashing and/or replacing the ECU. Any updates would be appreciated. Thanks.
XK Black
05-18-2015 02:17 PM
stevevaus
03-10-2011 03:09 PM
