Winter wheels for 2023 SVR
I have a 2023 F-Pace SVR with the 22" wheels. Looking to get a set of winter wheels and tyres - would like to step down to 21" or maybe even 20" if they will clear the brake calipers - to get more sidewall protection. So - couple of questions
1) does anyone know the detailed wheel specs for the 21" Style 5080, forged, Diamond Turned with Satin Technical Grey contrast wheels that come standard on the SVR? Looking for wheel width, offset (front and rear)?
2) what about 20" Jag wheels? Will they fit over the brakes?
3) is the wheel setup on SVR any different from other F Pace models? (On my prior XF the XF V8 and XFR models had very different rear axles and offsets than rest of the XF modes. So I'm wondering how interchangeable a non SVR wheel would be (or one from pre-facelift)
Finally - might consider going square vs wider wheels at the rear - mostly so I have more flex and fewer tire sizes needed...
Any input welcome from anyone here who has done this or got info on the detailed wheel specs
Thanks. Yes, I know the specs of mine which are the 22inch. That's a great site to look up others - I hadn't found a reliable site for jag specific wheels. Thanks for sharing.
It doesn't differentiate between F Pace models - so it suggests that the axles/hubs etc on SVR are same as all other f pace (issue on my XF was it took very different wheel offsets than the standard XF spec). Looks like 9 inch front and 10 rear all at ET45.
I'm assuming the big brakes on SVR will go into 20 inch wheels as they do on F Type and XFR. But prob not smaller than that. So maybe I downsize to 20s for winter.
I like several of the Jag options on that site - but wow at 6000-8000 usd for a set that's crazy money. Maybe I go aftermarket - I had a great set of Rohana RF wheels on my XF and they will make the right bolt/offset/hub etc
I'll keep looking on eBay for a takeoff set of 20s or 21s - just in case. But in the meantime I'll spec out aftermarket
One other question. Did all F Pace come staggered, or do some have same front and rear? I might switch to same front and rear as it makes it more flexible, one tire size etc.... Would likely do 9 inch wide for both and adjust rear offset to compensate
F Paces mostly came with a square setup. My S has 22’s and my 35t has 20’s. The SVR’s are special. I want one.
I sourced a tech grey set of Gyrodynes for my Type R from the UK via eBay. One at a time. Took all winter and shipping was not cheap. Got to know the DHL guy very well. Alternatively, look at Car-Part.com This is how I sourced a second set for my XF.
FYI for others looking for wheels, the specs at alloywheelsdirect.com are also not quite correct for my car. It shows my 22 inch wheel as ET 45 and front and rear when the wheels say 41 and 40
Maybe not a big deal but 4mm less space for calipers at the front could be an issue
Still working out what will fit the big front brakes on the SVR. It seems that the 22inch Jag double helix wheel will not fit at the front..
dmchao (09-27-2024)
@BritCars sorry to revive your old thread, but I'm taking delivery of an F Pace SVR this afternoon. I'll check my own wheels too, but was wondering your verified Offset on stock 22"s looked to be 41ET and 40ET Front and rear respectively?
I am planning to order some summer wheels next spring from LA Forged Industries so I want to get the offset/dims right and make the setup square 9.5 all around.
ChicagoSteve
03-06-2022 06:50 AM
