BCM/BPM
Old 04-12-2024, 05:15 PM
Sparky565706's Avatar
Default BCM/BPM
Hey I've got a 2002 Jaguar xk8 and I need a BCM with the part number LJE2500AD-164, the issue is, I am having trouble finding a module that has a matching vcat number (last three digits). Does anyone know of anywhere I can find a module with this number? I've tried eBay a few times but all of them either have the VCAT number 163 or are unmarked. Thanks
Old Yesterday, 07:16 PM
gbellefo's Avatar
Hi,
did you have any luck?
My 2002 XK8 is acting up too.
my suffix is 165 , finding one is proving to be a challenge.
btw
if you have issues with your tcm, the vcats number is actually printed on the module.
Old Yesterday, 08:37 PM
I had mine repaired but it did not fix my problem. And I still needed to get the module programmed by a dealership after that
Good luck
Old Today, 03:36 AM
dibbit's Avatar
The problem is that most breakers don't bother to copy the 3 digit number from the VCATs label onto the module, so you have no idea what it is. The best you can hope for is to try and find one from a coupe or convertible as appropriate with the matching module number and ignore the XXX. Any missing options can be programmed by WDS.
I would want to be 100% sure the problem was in fact with the BPM before buying a replacement - people seem to forget to check things like fuses, relays, switches, wiring and ground points, before deciding it must be the black box.
Deepstuff
General Tech Help
04-13-2024 05:35 PM
Sparky565706
03-20-2024 08:50 AM
TraxtarXKR
01-10-2024 09:24 AM
fast feline
07-30-2023 10:51 PM
Quick Reply: BCM/BPM
