F-Pace (X761) / C-X17 2016 - Onwards
F-Pace Coolant Leak - Help
Old 04-30-2024 | 09:15 PM
charlesn100's Avatar
Default F-Pace Coolant Leak - Help
Hi guys,
I have coolant leaking out, and it appears to be coming from one of the two hoses connected to the top of this box in the pictures. Does anyone know what this part is called or can point me in the right direction of how to fix this leak.
Old 05-06-2024 | 09:18 AM
Simonusa0's Avatar
Looks like a cooler. So if it’s dripping out of one of the hose joints then you probably have an o ring leaking at the connector or it’s the connector/hose itself. That can be easily remedied and much cheaper than replacing a cooler. Alternatively it’s leaking further up the hose and just running down and dripping off the lowest point. If it’s pink or orange color it’s definitely coolant. Go to your local dealership. Good luck.
Old 10-02-2024 | 02:11 PM
dmchao's Avatar
That's the transmission oil cooler. Uses engine coolant to heat transfer, like our other coolers. I think I have the same part leaking on my SVR, trying to trace it down.
Anna22
US Northeast
02-25-2023 08:27 PM
bfx308
05-15-2022 09:18 AM
asmass
US Midwest
08-26-2021 11:59 AM
Luis Antezana
06-17-2020 07:20 PM
carealtor
02-03-2020 08:41 PM
Quick Reply: F-Pace Coolant Leak - Help
