2008 Jaguar XKR Portfolio
For Sale2008 Jaguar XKR
Price
$18,000• OBO
- Location Weatherford, TX, 76086, USA
- Condition Used
- VIN SAJWA43C689B21180
- Mileage 62,252
- Engine 8 cyl
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Coupe
- Exterior Color Black
Description:
2008 Jaguar XKR Coupe, Portfolio Edition
- 4.2 L supercharged V8 rated at 420 HP; ZF 6-spd automatic transmission
- 62,252 miles
- Celestial Black paint, Charcoal leather and spun aluminum interior, Alcon brakes (400mm front, 350mm rear rotors), 525-watt Bowers and Wilkins sound system. A previous owner replaced the Portfolio spec 20” Cremona wheels with 20” Senta wheels.
- I purchased this XKR in July 2022 with 60,241 miles from a local Lexus dealership. The dealership was not able to provide the previous maintenance history. The selling dealership replaced the front Alcon brake rotors, the battery, and repaired the detached dashboard leather at purchase.
- Carfax reports this XKR was first sold in CA in November 2007 and has had three previous owners (in CA and TX). Carfax shows no red flags. The paint appears to be original with a few minor scratches and rock chips commensurate with its age and mileage. The XKR is offered with two keys and a clean TX title.
- The following maintenance and repairs were performed after I purchased it:
- Oil changes with Castrol Edge 5W-30 A3/B4
- Spark plugs replaced
- Engine air filters and cabin air filter replaced
- Fuel filter replaced
- Engine coolant, brake fluid, and rear differential fluid replaced
- Transmission fluid, filter, and mechatronic seals replaced
- All front/rear, upper/lower suspension control arms replaced
- Rear tie rod ends, rear stabilizer end links, and front sway bar end links replaced
- Rear brake rotors and parking brake pads replaced
I am just north of Dallas and may want to come see the car.
The headliner has no looseness or sagging. There is a small area on the driver's door panel, where the leather seems like it might be a little loose.
The tires are Michelin Pilot Sport A/S 3+. The date codes on the rear tires are 11/19. The front date codes are 31/18 and 50/18. I would say there is about 50% of the tread left on the set.
I would love to show you the car and could even meet you somewhere to cut down on your drive. Please let me know if you have any additional questions or would like pictures of any particular area.
Best Regards,
Retail: $24,200 - $18,100
Private Party: $18,800 - $15,200
Trade In: $16,200 - $13,100
I'm sick that this car wasn't available in January. I'd have bought it in heartbeat. Came out to Houston to look at one and returned empty handed. Found one in Indianapolis which I bought. My luck, this turns up after. Perfect companion for the 09 XJ Portfolio in Celestial Black.
Someone will take it. It's gorgeous.
