JLR has now produced Metal Cooling pipes for 2025
2025 F-pace SVR 575 has OEM Metal pipes for cooling pipes for the SVR a little late in the game but they finally listened after all the videos and discussions us members make, I wished they had listened
Unfortunately all metal is not an option for my 2012 XF 5.0 NA. However I recently fitted a new water pump (after 35k miles) and have just completed a 5000 mile round trip from Toronto to Canmore, Alberta and back without incident. No coolant was added during or after the trip, and the running temperature was steady at 188F, except for a high of 206F during afternoon rush hour through Chicago traffic.
l.clay.collins (06-11-2024)
Thanks Dennis, curious what you find. I probably should try calling the dealer but I don't have a VIN handy. I'm told 2024-2025 F Pace SVR and V8 Defenders have the metal pipes.
I grabbed these from a range rover forum, not sure if these are legitimate parts or not.
LR186859 upper crossover
LR186917 y pipe
LR186917 y pipe
Thanks much for the updated part numbers! It will be interesting to see how much these are compared to the after market versions? Now we will need to decide which ones to use?
I noticed that Jaguar stopped using that small failure prone coolant line from the front of the engine back to the coolant reservoir. BUT they just capped the front part of the port off and did not change the casting.
Cgo
02-28-2024 08:27 AM
