Another fan control module thread
I've only had one fan working for a while now. Read, read, and read some more and finally ordered a new controller.
Put it in yesterday and today the car overheated. It seems the new controller only spins the fans at very slow speed.
Tried the AC on coldest setting and no change. Tested both fans before plugging in new controller and they work full speed.
Getting ready to put old controller back in since it never overheated with it, but it's not correct either.
In addition to only spinning one fan it didn't seem to have any speed management, only full speed.
It also seems to stay on longer than I would expect after turning the car off. It does come on with AC.
The old controller has #'s 940.0040.03 & 301000299109 partial sticker, that one may be missing digits off the beginning.
New controller is beck/arnley part # BEC203-0291. The controller itself looks identical to the old but has #'s 3604-353 & 231127 on it.
This is on an 07 3.0
Edit... both controllers have the 4pin input, remember reading that cheap ones only have 3pins
Thoughts?
Thoughts?
Thoughts?
Thoughts?
You have to make sure the 4 pin receptor has metal contacts ineach female receptor. The cheap Asian ones do indeed have a 4 pin receptor, but lack the contact points in on female receptor as well as internally in the unit body they lack the appropriate wiring and relays.
The easiest for sure way to get the correct controller is buy a Gates FCM 134.
So I put the old controller back in and it did the same thing as the new controller, both fans slow speed 🙃
I unplugged the fan that wasn't working before and the other fan will run full speed with AC (and assume with temp) like before.
Being curious I reconnected the disconnected plug and unplugged the other plugged in fan. This fan also operates full speed with AC.
I'm assuming that the one wasn't properly connected before, either accidentally or purposely since it's been that way since I bought it.
So now I am back to square one, can't get both fans to run...
Anyone think it's possible both fans combined pull too much current causing this issue?
I'd hate to eat the cost of this beck/arnley controller then pay twice that for a gates and still be back to square one!
Just to update, put new fans in and all is well. Maybe the Gates controller is capable of putting out more amps than the others and why it's recommended? But if you are having issues it's simple enough to test current draw. I had one fan that was pulling just over 10amps @ startup and neither old or new controller liked it. Removed the motor and tested windings (no shorts) cleaned everything up (brushes looked real good) and oiled bearings but it would still barely pop a 10a fuse starting. It's half the price to replace the fans than a gates controller...
I presume since you haven't posted it is still working? Could you describe which wire goes to which pin on the beck controler please. I have a set of connectors to convert the old style controler to the new style but can't find any description of which wire goes where.
I'm still running the controller but wouldn't recommend it. The controller gets very hot in high ambient temps and cuts out. I may try moving it away from the already hot location it sits but currently I am only able to use it because high ambient temperatures are gone. I expect to drink the Kool aide and buy the Gates controller before next summer. I'll take a pic of the plug today or tomorrow when I have time...
It sounds like you've been through quite a bit trying to sort out your fan situation! If the new controller is only spinning the fans at a very slow speed and your car is overheating, it could be that the new controller is faulty or not properly calibrated for your setup, even if it looks identical to the old one.
Since you tested both fans before installing the new controller and they worked at full speed, it doesn’t seem like the fans themselves are the issue. The fact that the old controller ran just one fan at full speed and stayed on longer than expected might indicate a problem with the old controller's speed management as well.
Before putting the old controller back in, it might be worth checking a few things:
Also, be cautious with cheaper controllers, as you've mentioned about the 3-pin vs. 4-pin difference. The right one should be 4-pin like your setup to ensure proper operation.
Hope this helps you figure it out!
Ryan
https://gpstrackershop.com
- Wiring and Connections: Double-check that all the wiring and connections are secure and clean. Sometimes, a loose connection or corrosion can cause issues with fan speed control.
- Temperature Sensor: Make sure the temperature sensor is working correctly. If the controller isn’t getting the right readings, it might not activate the fans at the right speed or time.
- Controller Compatibility: Even though the new controller looks identical and has the 4-pin input, the internals might differ slightly. There could be a compatibility issue with the Beck/Arnley part in your specific setup.
Ryan
I didn't forget you but when I went to get a pic I noticed the connector was aftermarket with all black wires. Mine is an 07 so not sure why the original was cut off. Anyway, finally got time to pull back some loom and tape for wire color. The green/white wire goes to part of the connector with the release tab and the blue/white wire to the opposite end. The + & - supply wires were further down loom then I could see...
Blue/white wire is the PWM control signal that denotes the fan speed and whether just one or both fans are required to operate. (140Hz positive signal, ranging from 7% to 95% duty cycle to moderate fans).
White/Green wire is a EMS relay switched supply - only a 5A fuse, so just a control/logic supply to the controller.
Brown/Green wire is the main 12v supply to the fan controller which is via a 40A fuse.
Venko007
34
05-18-2024 10:30 AM
03Xtype
05-19-2012 07:31 PM
