Removing Interior B-Pillar Trim
Old 07-02-2024, 09:36 AM
87LC2's Avatar
Default Removing Interior B-Pillar Trim
Did a search and couldn't find anything - How is the interior B-pillar trim removed? The trim that's between the front/rear doors and goes up to the headliner. Any help appreciated.
Old 07-02-2024, 11:27 AM
Jaroslav Záruba's Avatar
the Workshop manual PDF, page 5652 / 6470
the Workshop manual PDF, page 5654 / 6470
Old 07-02-2024, 11:35 AM
87LC2's Avatar
Thank you! Doesn't seem too bad, seems they're mostly held in with clips. Appreciate it.
Jaroslav Záruba (07-02-2024)
Old 07-02-2024, 02:33 PM
I have replaced mine three days ago, and it was indeed reasonably easy.
The only slightly annoying part was to line up the seat belt slider plate with the B-pillar trim slider plate. Only now I am noticing the note in the manual that suggests to put them both to their lowest point to line them up...
Old 07-02-2024, 02:50 PM
87LC2's Avatar
Interesting, thanks for the tip. So no issues taking any of that apart? Seems reasonably easy in the manual, just curious if you ran across anything that gave trouble.
I just had my headliner done at a local shop and they recovered the a-pillars, but did not re-cover the b-pillars. After seeing the car they look pretty bad when compared to the new headliner, so I may take them out myself and bring them over to the shop for recovering.
Old 07-02-2024, 03:38 PM
Actually thinking of it, you also need to take off the inner door seals (partially, as indicated in the manual), and for that you need to take off the plastic panel on a door sill... And given I never did that before I was afraid something would break - but it was fine...
Here's a video I followed for that particular operation:
I wish that guy never sold his XJ8, his video-guides are 10/10
87LC2 (07-02-2024)
Old 07-02-2024, 04:14 PM
Actually, I think you can easily take the seals off partially without touching the plastic thing. I suppose I complicated things for myself. 😁
At least I practiced for the other side where I was actually replacing the seal itself. (For the same reason the guy in the video messed with his.)
87LC2 (07-02-2024)
Old 07-02-2024, 04:16 PM
87LC2's Avatar
Yes, very helpful. Thank you again.
KRT
04-17-2022 05:11 AM
Evoking
09-16-2013 06:17 PM
US Scrap
07-04-2012 01:37 AM
Abacab
12-09-2011 04:23 AM
Quick Reply: Removing Interior B-Pillar Trim
