Is power steering shudder actually fixable?
Received 10,906 Likes
2005 S-Type 3.0 V6
My car has the oft-mentioned power steering shudder in garage/ parking scenarios. It is very slight...but now that I've become aware of it, it is a bit of an itch. The Jaguar TSB for power steering noise often comes up.
The original intent of the TSB was to fix a noise problem. I've read a LOT of prior postings which mention trying the C2S48887 power steering additive for the shudder complaint as well. Problem is, I've yet to find a case where the shudder has been cured with the additive.
If the success rate has truly be zero then I'm not anxious to go thru the additive ritual just for fun, so to speak.
Thoughts? Has anyone fixed the shudder? If so, how?
Or, realistically, should I just shrug it off?
Many thanks
Doug Dwyer
PS- I should mention that the p/s fluid is fresh.
Many thanks
Doug Dwyer
sunchip
01-28-2015 08:21 AM
