Help! Correct part numbers for V8 NA coolant Y pipes?
Since I have developed a coolant leak after replacing injectors, I've decided I might as well replace every plastic pipe and hose I can. I have every part in my shopping cart except the 2 Y pipes. I'm talking about the 2 pipes where, if you have a supercharged version, they can be found in metal. I'm wracking my brain trying to find the plastic ones for the NATURALLY ASPIRATED 5.0 V8, and every parts site and diagram I can find points only to the SC version, whether metal or plastic. I can't find a single post in the forums where anyone has replaced them on an NA engine either. My mind has turned to mush... Am I crazy? Does the NA cooling system not even have those 2 pipes?? Does anyone have the part numbers or a link to a diagram? Thanks!
Hi Sandcat & welcome to "THE FORUM"!!
Our 2012 XJ NA has been great, hope yours will be as good to you too.
The NA engine doesn't have the same frontal cooling pipes as the SC.
The outlet pipe for the NA is AJ89664 and isn't available in aluminum - yet...
Thankfully for us NA owners, the cooling system has a couple less parts.
See item #25 in this diagram
Radiator & Components for 2012 Jaguar XJ | Jaguar Annapolis Parts
Sandcat (07-13-2024)
sjhesketh
05-06-2024 01:30 PM
