I have an XJR which is leaking which i believe is engine oil.
It seems oil drips from the transmission housing?
Could be the rear main seal but there is a connector above where it's dripping what is covered in oil also.
The bolt of that connector is tight.
I don't know if that connector could leak.
Please see my video, maybe you can push me in the right direction.
Maybe coincedence but the leak started after an oil change and it seems they filled it up with too much oil?
