2000 X308 Octopus Hose modular disconnect.
Old 07-12-2024, 11:51 AM
AZ VDP's Avatar
Default 2000 X308 Octopus Hose modular disconnect.
Suggestions on how to disconnect and reattach from yellow circle. I have identified a leak coming from from the old hose at the blue circle connector. I have disconnected the blue circle connector already. I dont have the ability to change the entire assembly. Even if its rigged somehow, I would aporeciate any help on this one. Any ideas at all....
Old 07-12-2024, 02:12 PM
Addicted2boost's Avatar
Received 1,089 Likes on 839 Posts
Marked in yellow, In order to get that off, you’d have to cut that steel band off. It’s a pretty thick band so I don’t suggest trying to cut it.
I know you said you can’t replace the entire assembly but, marked in red is a plastic check valve. These days I’m coming across more and more of those leaking because they split lengthwise. I’d highly suggest replacing the entire hose assembly. If you cannot diy, get a shop to do it.
However, the one currently on your car you could cut the plastic Norma connector off right where the plastic meets the rubber hose, clean the metal pipe with a wire brush, Brillo pad or even sand paper to get any crusty schmotz off, wipe it off until dry, install a hose clamp on the hose and slide it on the metal pipe about 1.5” until it’s over that bump ring (?) roughly 3/4” past then tighten the hose clamp.
I *do not* condone any half *** repair like I explained unless it’s an emergency. I will always suggest replacing the entire hose but, you seem to be in a bit of a pickle so there’s my response. If you choose to not replace the entire hose assembly and you use my shortcut, do so at your own risk. Me nor anyone else wants to see any bad outcome from this.
Good luck!
Old 07-12-2024, 05:41 PM
AZ VDP's Avatar
Thank you sir! I am indeed in a bit of a pickle. At full knowledge of risk involved, I will cut off the Norma Connector and clean the metal pipe. I just replaced the water pump on my 2000 XJ8 VDP a month ago. Now this octopus leak is from my XJ. It's 114 degrees Fahrenheit outside right now. My two 2000 XJs are the only cars I have. My choice. Love the cars, but they are definitely built for cooler climates.
Thank you again. Will update when complete.
Old 07-12-2024, 09:40 PM
vincent661983's Avatar
I replaced this before (not by myself )
Sorry to say but you must replace the whole octopus hose.
If you cannot do it..have the stop to do it.
This hose runs on pressure all the time and right on top of engine.. You don't want to cheap out on this.
Old 07-13-2024, 02:28 PM
AZ VDP's Avatar
Default Temporary repair.
I appreciate the input on this thread. I rea
lize that a full replacement would be the safest and most reliable repair. However, with full knowledge of risk and responsibility, I cut off the Norma connector, cleaned the metal hose end, and reattached thr remaining length of hose. I have no leaks and am on the road again, for a little bit anyways.
Old 07-15-2024, 03:14 AM
RandyS's Avatar
I would get that sorted at your first opportunity. "Work arounds" are great
until they aren't. There was a time in my life when expediency was paramount
and I learned to regret it.
vincent661983 (07-15-2024)
giandanielxk8
03-18-2024 07:41 PM
Ophitoxaemia
10-29-2022 08:16 AM
vsol
05-10-2017 01:05 PM
srpope80
01-26-2012 04:02 PM
SilverXJ
06-01-2010 12:06 PM
Quick Reply: 2000 X308 Octopus Hose modular disconnect.
