Power Mirror Control - I'm Baffled
1998 (MY '99) XK8 X100 Convertible
My mirror adjustment hasn't worked properly since I bought the car. There was also a problem with the drivers door window switches and I expected that when I took the drivers door switchpack apart and cleaned it up, full operation would be restored. Sure enough, the windows worked fine but the only element of the door mirror adjustment that worked was the upwards vertical movement on the passenger side. I checked all the wiring for continuity between the switchpack and drivers door module and between the module and the drivers door mirror - all good. I assumed, then, it must be the switchpack and so replaced it with a known good one - no change. I next moved onto the drivers door module and got a replacement, here's what I've found:
It feels like a programming problem and maybe some configuration changes are needed. Any other ideas or suggestions? You can see that I know some basic troubleshooting steps but I've reached my limit...
Mark
- WIth new or old switchpack and with the original door module, I only have upwards vertical movement on the passenger side mirror
- WIth either switchpack and with the replacement door module, I only have downwards vertical movement on both the passenger and drivers side mirrors
- When I swap the modules, the drivers side electric window switch operates the passenger side windows and the passenger side switch (in the driver door switchpack) doesn't operate anything. A module reset putting the +ve and -ve battery cables together fixes the window issue but has no impact on the mirror movement
Mark
You say you had a known good replacement switch pack - how did you know? Did you test the switchpack out of the car with a multimeter before installing it?
The window operation getting swapped suggests the modules learn which side they are on and the reset cleared that learned behaviour - door modules with the same part numbers should be directly swappable without programming.
Please update us with what happens when you swap the passenger and drivers door modules to see what that reveals.
Pristine97XK8Convertible
08-25-2017 04:15 PM
