I live 90 min from the nearest dealer. I took my misfiring 2015 XF 3.0 AWD to get some codes, and here they are in the order they came out. 75k miles
P2187
P2189
P0300
P0303
P0306
P0162
P1315
P0061
P0301
P0302
I was driving about two weeks ago and felt the misfire settle in. I ran some injector cleaner through the car and it went away for a bit. Now it seems it's back with a vengeance, which is why I took it in for a scan. I have a check engine light but I've been driving it so as not to make it flash, it only flashes if I press the accelerator down too hard. Then it stops. Ill admit I ran some lower octane through it for a bit (absent-minded, this is my only car that requires premium fuel).
TL: DR I have a misfire on 1,2,3,6 on a 3.0 XF sport.
any thoughts?
P2187
P2189
P0300
P0303
P0306
P0162
P1315
P0061
P0301
P0302
any thoughts?
Here are pics of my plugs and coil packs
I pulled out 1, 3, and 6 today. I got the codes from this whole side and #6 from the drivers side In order from top to bottom: 3 2 1
#3 has the tiniest bit of oil on it.
