XJ40 ( XJ81 ) 1986 - 1994
Fuel Fail 44
Old 07-17-2024, 10:01 AM
Stefi88's Avatar
Default Fuel Fail 44
Hello everyone,
Recently i have been having an issue with Fuel Fail 44 and the accompanying check engine light.
Namely, i have no symptoms besides the FF44 popping up as soon as the car warms up.
I have replaced the O2 sensor to no avail. occasionally if I am stationary when the car reaches operating temperatures there is a slight change in RPM, the needle goes from 650 to 750, then drops to 550, only to level out again at 650 and turn on the check engine all in a space of one or two seconds. From then on the car drives just as it usually would only with the FF44 check engine light on.
I have also noticed the increase in consumption expected for this condition.
Please let me know if you have any ideas as to what the problem might be, and thanks so much to everyone in advance!
Kindest regards,
Stefan
Old 07-17-2024, 11:49 AM
Received 8,151 Likes on 4,917 Posts
Please read the Tech Guide S91_AJ6 4.0 Engine Management.pdf
Gus will have it on his site. (jagrepair.com)
Khoahli
06-26-2024 03:17 AM
ericnunez
05-01-2023 12:34 AM
EXMUCKER2112
07-04-2022 08:53 AM
dartech
04-09-2016 09:28 AM
louiloui
06-21-2012 09:54 PM
Quick Reply: Fuel Fail 44
