Also, I spoke with SNG Barratt here in the U.S. about these oil cooler lines in mid-April. They quoted me a full kit to replace all components in the system. Their quote included oil cooler feed hose C2N2911, oil cooler feed hose C2N2208, oil cooler return hose MJE7471AB, oil cooler return hose MJE7461AB, 4 O-rings KSR609001, and 2 O-rings KSH119530. So these parts may still be available through SNG Barratt (although they are stupid expensive)....
Yes, I replaced the O rings, I have a few o ring kits and just matched up with the closest in the kits, the closest match came from an imperial rather than metric kit.
I found out something new today, after assembly I started the engine to check for leaks and noticed after 10 minutes the oil cooler and pipes were still cold.
This is why.
here’s more detail, showing the valve and oil path. It’s been posted in the previous oil cooler topics if searching for more information about the oil cooler and assorted issues is desired.
Good one ya! That sounds very reasonable to me. Didn't your hose guy have a yacht payment due this month? Mine seems that I should send his kids to college for the privilege of having hoses fitted by he and his shop. Bragging rights I suppose. Glad you solved the problem. TM
