Timing chain tool set
Old 08-01-2024 | 12:59 AM
Throwback's Avatar
Default Timing chain tool set
Has anyone tried this timing chain tool set? Only 45 bucks on amazon. I am inclined to try it as doing secondary tensioners and I don't like the idea of actually removing the exhaust cam if i dont have to. It was only sticker shock leading me to the zip tie method, but doing it the "proper" way appeals if the tools don't set me back too much.
Figured ill try it and abuse Amazon's return policy but curious to hear if anyone's used it.
Amazon Amazon
User 42324 (08-02-2024)
Old 08-01-2024 | 03:06 AM
bladerunner919's Avatar
I bought the same sort of thing from ebay and it's perfectly good.
Old 08-01-2024 | 03:42 AM
RichardS's Avatar
https://www.amazon.com/DPTOOL-Camsha.../dp/B09BV9TCDT
It's many years since I did it, but if I recall correctly if you don't unbolt the exhaust camshaft then you have to remove the sprocket from the end of the camshaft and that is a really tight interference fit as there is no woodruff key on the shaft.
If you have a torque wrench then removing the camshaft is actually very easy. Turn the engine with a spanner on the crankshaft to a point where all the valves as a closed as possible and then progressively loosen the cap bolts. Note which cap goes where (I think they are numbered and arrowed). Installation is the reverse. The hardest part of the job is removing the cam covers as one or two of the bolts are not easy to access.
Richard
Old 08-01-2024 | 02:21 PM
Hell-Cat's Avatar
That toolkit will work fine for the top-end.
But.....if you are going this far you might want to consider pulling the timing case cover and also replacing the primary tensioners and guides, you will also need the crank pulley lock for this procedure. It isn't a huge amount of additional work to just doing the secondaries.
If you're on the fence about the additional work, drop your old pan and check for any horrors in there (e.g. pieces of chain guide). Doing so will give you some guidance on what really needs to be done.
cjd777 (08-01-2024)
Old 08-02-2024 | 03:11 AM
That toolkit has the equipment to deal with all the tensioners.
Old 08-02-2024 | 11:23 AM
Hell-Cat's Avatar
Yes it does, but you will need the crank pulley lock to remove the harmonic balancer prior to removing the front timing cover.
Old 08-02-2024 | 11:54 AM
Yeah, but that's not part of a timing kit. You also need a puller for the harmonic balancer.
Old 08-02-2024 | 12:29 PM
Hell-Cat's Avatar
The puller is usually included with the cranklock toolkit or at least all of the toolkits I've seen.
Old 08-03-2024 | 07:15 PM
JagWRLD's Avatar
This kit has the locking tool, I purchased the same one. However, if you are doing both the upper and lower tensioners, the only thing extra you need is the tool to remove the harmonic balancer. (and a big, big torque bar).
Old 08-03-2024 | 11:23 PM
giandanielxk8's Avatar
Last time I used the harmonic damper locking tool and a 2 foot breaker bar with a 6 foot steel pipe sleeved over the breaker bar to break the bolt loose. It made it a cakewalk. The only issue was I accidentally whacked one of the lamps hanging from my garage ceiling.
Old 08-04-2024 | 06:58 AM
Hell-Cat's Avatar
I'm afraid not, the camlock kit does not have a crank lock. There is a crank positioning tool but this for positioning the crank only, using this to hold the crank while you undo the front crank bolt will damage the transmission driven plate.
The cranklock is in another toolkit that looks like this: https://zimber-tools.eu/rs/engine-cr...ann-tools.html
+ the mandatory breaker bar and 6 feet of steel tube - eat your wheaties before this job....
Old 08-04-2024 | 08:03 AM
I undid my balancer bolt in about 2 seconds with a mains-powered impact wrench - didn't even need a locking tool, as it's such a beast!
Old 08-04-2024 | 10:05 AM
Did you remove the radiator to be able to fit the impact wrench? I tried the impact on mine but there wasn’t enough room with the radiator in place.
Old 08-04-2024 | 10:35 AM
Throwback's Avatar
Well I'll be trying this today. Not doing the guides or lower, because I've inspected them with a borescope and they are fine, and the engine has less than 50k on it. At least one secondary is cracked, because I checked it a week ago, triggering this work. Also, I just don't think I can do the whole job with lower tensioners and guides in one day - a lot has to come off the front of the engine to get the timing cover off, I'd ideally want to pull the radiator fan shroud for access, haven't filled/bled the cooling system on this car before, and I don't have a garage to work in - I have to work outside. And I definitely don't want to leave the front of the engine open for more than a day, outside. So it is what it is. I feel doing the uppers is at the limit of my skill level at the moment. If I could leave it open in a garage I might be more inclined, but don't feel I have motive and opportunity for that lol.
Remains to be seen how painful it is to unbolt the sprocket versus unbolting the cam. That sprocket needs quite a lot of torque (115-125NM) going through a hex bolt. So I will make that decision once I have it open. I am still glad I got the tools to set and lock the engine at TDC, which I feel would also help with guaranteeing all valves are closed if I do lift the cam. Re clearance on that sprocket bolt as someone mentioned above, I am assuming that's why JTIS says use a long 10mm ball ended hex drive bit and to cover the cylinder head on the potential contact point:
Old 08-04-2024 | 11:42 AM
RichardS's Avatar
I do hope the job goes well but, if you do have any second thoughts about removing the cam sprocket, I can perhaps ease your mind by saying that unbolting the cam is so straight-forward that it is difficult to get it wrong.
Richard
Old 08-04-2024 | 12:27 PM
Ah yes, I should clarify that I have the engine out of the car!
Old 08-04-2024 | 07:41 PM
Throwback's Avatar
Richard
After 10 minutes of heaving on the barsteward with all my strength in a very awkward position, I pulled the cam shaft instead. Much easier. Also, finding TDC and locking the crankshaft with only one person is a massive pain in the **** cos you either have to set up a remote camera, which I didn't have handy, or have a second person barring the engine over while you look out for the mark on the timing wheel. A second pair of hands would probably have made pulling the sprocket easier, but I didnt have another pair.
So after much time wasting with finding TDC and all that, I did it the trusty zip ties and remove the cam way, and got one side done before running out of time and energy. Ill do the other next week. So today I learned how to bar an engine over, so that's something and how to find TDC (even if it was unneccessary) so you lives and you learns.
And yes, my upper tensioner was cracked in the traditional location.
The toolkit did have all the right stuff for locking the cranks, cams etc though, so that's nice.
Still flabbergasted that the previous owner had the valve cover gaskets done, but not the upper tensioners.
RichardS (08-05-2024)
Sacho
07-03-2018 07:48 AM
jimmiejag
05-27-2014 06:39 PM
R as in Rocket
02-22-2012 11:28 AM
Quick Reply: Timing chain tool set
