Airbag light on B0002-1B
Old 08-02-2024, 11:33 AM
Ajmanning68's Avatar
Default Airbag light on B0002-1B
Hi
I have a 2007 XK and getting a constant airbag light on I have already tried
1. Car has new battery and is fully charged
2. Cleared the fault it comes straight back
3. Took front drivers seat out and disconnected all the plugs sprayed them with electrical contact cleaner
could this be the clock spring? Or something else
thanks in advance for any thoughts or suggestions
Old 08-03-2024, 08:43 AM
Stuart S's Avatar
Received 6,390 Likes on 3,501 Posts
@Ajmanning68 Welcome to the Forum. You'll find lots of knowledgeable and helpful members here. But you need to help us to help you by creating a signature and completing your Public Profile, as detailed in this thread:
https://www.jaguarforums.com/forum/n...-up%2A-241802/
Regarding your airbag warning light, don't guess. Always search this Forum first, before doing anything else. The X150 is almost 20 years old, and almost every question you can think of has already been asked and answered. Here's the answer to your question:
See Post #16, by Forum Moderator GGG:
https://www.jaguarforums.com/forum/x...solved-246884/
How did I find that? It's easy, if you know how to do it. Read this:
How To Find Answers To Your Questions
Stuart
Old 08-03-2024, 10:02 AM
Hi Stuart,
Thanks I have updated my signature. I should have mentioned I had scanned the forum and looked at the possible solutions hence I had gone through checking the connections under the seat and clearing the fault using an icarsoft device but still no joy as it just comes back as soon as the car gets to about 10 mph
Regards
Adrian
Old 08-03-2024, 02:23 PM
Stuart S's Avatar
Hi Adrian,
Are you certain that your iCarsoft device is able to clear and reset that warning light? I highlighted in yellow Graham's important points. The link is above, in Post #2.
Please let us know the model number of your iCarsoft device.
Thanks,
Stuart
Old 08-03-2024, 02:30 PM
It is the icarsoft v2 Land Rover /jaguar version I have only just got it so still trying to get familiar with its capabilities but it was giving me a 7 digit code B0002-1B which was intermittent
The following 2 users liked this post by Ajmanning68:
McJag222 (08-03-2024), Stuart S (08-03-2024)
Old 08-03-2024, 04:58 PM
Sean W's Avatar
Received 4,267 Likes on 2,384 Posts
You can download the service manuul here:
https://www.jaguarforums.com/forum/x...guides-215509/
It will steer you in the right diection.
Old 08-03-2024, 06:27 PM
Old 08-11-2024, 03:47 PM
So just wanted confirm that I replaced the Clock spring and it has resolved the airbag light on issue. The removal of the airbag was the hardest part of the process I used a screwdriver and an adjustable spanner on it to give leverage to turn the screwdriver and pull the airbag out.
Thank you everybody for your input
The following 7 users liked this post by Ajmanning68:
Cee Jay (08-11-2024), kj07xk (08-12-2024), luv2fly (08-19-2024), ralphwg (08-11-2024), Sean W (08-11-2024), Stuart S (08-12-2024), V7Sport (08-12-2024) and 2 others liked this post. (Show less...)
Old 08-12-2024, 07:23 AM
V7Sport's Avatar
Thanks for the follow through on providing the resolution to your problem. 👍
Sean W (08-12-2024)
JoonasJaguar
07-20-2024 06:28 AM
sashoivanov78
02-01-2014 03:12 PM
chazaroo
03-21-2012 04:41 PM
pnyklr
02-07-2010 11:51 AM
apollo022777
04-16-2008 07:56 PM
Quick Reply: Airbag light on B0002-1B
