Check Engine Light - Multiple Cylinders Misfiring
Old Yesterday, 01:30 PM
XKDreams's Avatar
Default Check Engine Light - Multiple Cylinders Misfiring
Welcome.
It would help if you identify the model & year.
Old Yesterday, 01:54 PM
JaguarJimmy's Avatar
Sorry, 2004 X-Type 6 cyl 3.0L
Old Yesterday, 04:26 PM
Received 3,960 Likes on 2,861 Posts
Welcome aboard Jim.
Old Today, 12:38 AM
Received 10,504 Likes on 6,936 Posts
Welcome to the Forums.
Since this is NOT the Tech Area for any Jag, A re-ask in the X Type (X400) Tech Section will get you sorted.
Good luck.
Old Today, 06:47 AM
I have a 2004 X-type 3.0L and my check engine light came on last week and the codes are “random misfire” and 5 other codes telling me that cylinders 1,2,3,5,& 6 are misfiring (I should have recorded the exact code numbers and can do that if necessary). I am also getting a mass air flow sensor code intermittently, but just replaced the MAF a few weeks ago. The car runs rough at cold start for about a minute. It drives well after it is warm, but do notice there is a slight loss of power when accelerating.
The car has 55,000 miles (was stored for several years and now my son drives it – very little). I have a hard time believing it is spark plugs and ignition coils with so little miles? The first thing I plan on doing is swapping the ignition coil from cylinder 4 to misfiring cylinder 2 to see if the code switches from cylinder 2 to 4. If that happens I will proceed to replace all of the coils. I will also remove the spark plugs from the front bank and inspect. I will replace those anyways. I am a little afraid to do the rear bank of plugs due to the fact that you need to remove the intake.
Does this sound like a plug/coil issue to anyone since 5 of 6 cylinders are misfiring? Does it sound more like an injector or cam position sensor? I am going to use some Seafoam in the gas tonight with low gas level. I have replaced the mass airflow sensor and cleaned the throttle body.
Any advice would be welcomed. I may have to take it to a shop to have it properly diagnosed.
Old Today, 08:34 AM
Received 6,322 Likes on 5,509 Posts
Welcome to Jaguar Forums Jaguar Jimmy,
I've copied your post to the tech section, follow this link to find it https://www.jaguarforums.com/forum/x...sfires-282703/
Old Today, 08:47 AM
Thanks for the help!!
Old Today, 09:55 AM
Received 9,289 Likes on 5,418 Posts
Hello,
Old Today, 01:09 PM
Received 4,299 Likes on 3,716 Posts
mxd
04-12-2023 05:23 PM
MyFirstJag02
11-24-2019 05:42 PM
Jaw Godsquad
09-14-2017 06:34 AM
Craig McNulty
05-10-2009 10:32 AM
Quick Reply: Check Engine Light - Multiple Cylinders Misfiring
