Suggestion on Japanese? Timing kit for new xkr 2000 owner.
As for the tensioners, first pull a valve cover and look at the chain tensioner, if the entire body is plastic, you need to upgrade them ASAP or risk catastrophic engine failure. If they are the metal bodied 3rd generation tensioners you’re good to go.
I can’t help you with a kit as I have never had to deal with that.
あの、何の日本語の提案を欲しいしますか。
I'm afraid that I don't understand the reference to "Japanese". I guess that you mean a quality kit vendor?
Once you've checked the tensioners as advised by giandaniel, you might not need any kit at all. I suspect that you will find that you already have the all-metal tensioners.
Richard
Richard
friendlyjoe
05-07-2018 11:13 AM
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
