Restricted performance mode and check engine need help!
Old Today, 05:46 PM
Mogi83's Avatar
Exclamation Restricted performance mode and check engine need help!
Hey folks, recently got a 2000 XJ8L over the summer with 60k miles and its been driving fine until mid month last month. Its been real hot where I live and one of they days I went out I saw the restricted performance message pop up and my car started shaking, not super violently but similar to an idle engine but with a bit more of a bump each time. Sorry if that isn't specific enough as to how far the shaking is but I have more info. The 2nd time I took it out I got check engine lights and have since gotten an OB2 scanner and read the codes:
#1 P0308 Cylinder 8 Misfire Detected
#2 P1314 Misfire Catalyst Damage Fault Bank B
#3 Ignition Coil H Primary Control Circuit/Open
From what I've read I should go replace the the set of ignition coils and see if I still have the issue but I wanted to reach out here as this forum has been useful for finding fuse diagrams and yall are much more experienced with these cars than I am. My scanner can read live data and I took a snapshot while the car was running with the shake see attachments:
Im not the most car savy person but I can follow instructions, what is the right steps I need to take to fix this problem? Im using this car to go to college and I don't have the money to take this into a mechanic without putting it on a credit card or something.
Non critical unrelated problem when I was replacing the fuses to get the cigarette port power again my passenger door no longer auto locks (it used to but I clearly messed something up), I still got a full pack of fuses if anyone knows what fuse is causing that or why id be appreciative.
Thanks.
Old Today, 07:46 PM
Silverjag0's Avatar
I'm not sure if 1 bad coil would do restricted performance I had burnt coil no codes except engine was not smooth anyway I would disconnect the battery for while that's for the door lock , check if it's the coil or spark plug you can pull the coil while the engine running see if there's sparks or not if no get new coil rock auto have them I think 23$ for aftermarket coil or get used coil pack set from ebay
Also check if there's oil leak around the spark plugs oil leak can cause misfire and lastly clean the MAF with MAF cleaner but first fix the coil issue
dantheman1
12-15-2020 05:01 PM
robert53
08-08-2020 07:54 PM
OZXK8
08-07-2016 09:33 AM
zmann96
11-03-2010 07:48 PM
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
Quick Reply: Restricted performance mode and check engine need help!
