Sportbrake's boot styrofoam etc
Hi all,
Does anyone have a picture of what is supposed to be in the sportbrake (2013) boot, my floor is sagging so it must be something missing like a foam tray and other stuff. I have red spare wheel, and few bits, but that's all.
Any help would be appreciated.
Thank you!
Thank you!
I have a compressor, the plate is not deep. the edge of the tray has a thickness of 15 mm which actually rests on the rail, which allows the trunk carpet to be maintained in height without it sagging.
Height of the tabletop
Without the foam tray
You could put two bars of scrap wood 15 mm (0,59 pouces) high while waiting to find a tray so as not to damage the trunk plates, I did not cut this example.
Hi,
Thank you very much for the pictures. I used 70cm lenght 16x16mm sticy back trunking on the rails and now it sits flat, no sagging. I understand I have no support across the boot but this is just temp solution till I get the tray and I won't be loading car with heavy goods. Found picture of shallow tray with spare wheel, this is very hard to get!
Horse on a Beaxh Ball
08-01-2024 10:28 AM
