1994 XJS V12 6.0 no start/run
Old 08-19-2024 | 11:09 AM
kansanbrit's Avatar
Default 1994 XJS V12 6.0 no start/run
Got the old girl out yesterday, started fine but idled a little rough. Tried to give her gas would not respond. Eventually died. Then nothing when cranked. Looked at her today. Some fuel comes out the rail supply pipe when disconnected but nothing comes out of the regulator out port at any time when outlet pipe left disconnected. Tried powering both pumps directly, both run but no fuel comes out of reg port ever. So some fuel supply but not enough pressure to open regulator I'm thinking. What could be limiting the pressure? I notice a 'damper' in the fuel lines, anybody know if that could be the source of my problem? All the injectors stuck open? No smell of fuel. She ran great a few days before, loads of power and smooth running.
Edit: Fitted a pressure sampling port. 0 PSI pump 1, 5 PSI pump 2. Surely they can't both be faulty ? That would be my luck !
Old 08-19-2024 | 12:48 PM
kansanbrit's Avatar
I fear I may have discovered the likely issue.
Greg in France (08-20-2024)
Old 08-19-2024 | 02:57 PM
equiprx's Avatar
He sure does a lot of talking about stuff we couldn't give a damn about.
I wrote a post years ago about how after pulling the tank in my 94 6.0.
Almost every hose inside the tank had loose clamps and one hose was completely disconnected.
The following 3 users liked this post by equiprx:
Grant Francis (08-20-2024), Greg in France (08-20-2024), JJS- Florida (10-28-2024)
Old 10-27-2024 | 04:57 PM
Jaguaralfonso's Avatar
The fuel pump N2 only acts when 2850 rpm is exceeded... Until then I think that the pump N2 does not activate and if the N1 does not provide pressure, try to see if the fault is in the Pump 1 relay that has the yellow socket, changing it for that of Pump 2 with a green socket
Old Today | 05:49 AM
kansanbrit's Avatar
Default Solved
Pump housings were both broken internally, had to modify them to stop them leaking. Good pressure now. Lots of photos if anyone needs them.
Greg in France (Today)
Old Today | 07:05 AM
Greg in France's Avatar
Please post the photos!
AZDoug
10-22-2023 03:00 AM
billythequid
02-10-2023 04:36 AM
Jeff4605
07-18-2022 05:48 PM
88-xjsv12
01-23-2022 10:07 PM
J_C_R
11-14-2012 04:54 PM
Quick Reply: 1994 XJS V12 6.0 no start/run
