XJ40 ( XJ81 ) 1986 - 1994
Trunk Lock Issue
Old 08-22-2024 | 01:44 PM
etaent's Avatar
Exclamation Trunk Lock Issue
Hey guys got a weird one here. So when I first got my 1992 XJ6 Sovereign, the trunk lock worked intermittently. Sometimes it would activate the lock when I locked the car, and sometimes it wouldnt and the trunk would be accessible despite every other lock being secured.
In my quest to make the car perfect, I decided to put some white lithium grease in the key hole to lube it up. Now, the lock works perfectly every time. The only concern I have is that now it makes this horrible sound when unlocking. I have included a video for you all to hear.
Should I be concerned? Is this a normal sound? Any idea what it could be and how to address it if it is not?
Thanks in advance!
File Type: mov
Old 08-24-2024 | 07:31 PM
jerry_hoback's Avatar
Mine makes that noise. Its the lock actuator. I took mine out to see if I could fix it but the unit has plastic gears inside. I think theres a place that rebuilds them but I havent had that problem rise high enough on "the list" as yet.
etaent (08-26-2024)
Old 08-26-2024 | 09:25 AM
etaent's Avatar
Do you know the place that rebuilds them?
FredA101
03-18-2022 05:11 PM
losfinch
12-03-2021 08:26 AM
MIFoodie
11-13-2017 06:45 PM
JayCee
05-23-2016 07:36 AM
jagyankee
12-21-2013 07:50 AM
Quick Reply: Trunk Lock Issue
