Trans leak help identify pls
Old 08-22-2024, 10:02 PM
Psycom's Avatar
Default Trans leak help identify pls
Just found this leak and in the one picture there's what looks like a electrical connection that's looking pretty wet. Would this have anything to do with the P0715 Input Speed sensor issue I've been having recently?
See the plug about mid way on left... what is it?
Old Yesterday, 04:43 AM
xjack's Avatar
Dirty brown is probably engine oil leaking from output shaft or plug on the back of engine, but it could be leaking sump gasket
Try to track that red drop, does it come from power steering or the tranny?
No, it isn't related to the error, it is just bonus
Psycom (Yesterday)
Old Yesterday, 08:30 AM
RandyS's Avatar
Transmission fluid leaks can occur for various reasons, such as damaged cooling lines,
worn gaskets, and cracked seals. Tracing the causes of these leaks can be difficult.
It is very important to address them quickly and determine the fluid level in your tranny.
Low fluid levels can cause damage to your Jags’s transmission system. Some members
have found
the issue is the cooling lines leaking where the pipe becomes a hose. The
crimps there were reported to be of low quality and cannot be tightened up.
Old Yesterday, 11:24 AM
xjack's Avatar
And if the red drop comes from gearbox then it is not filled with correct fluid
motorcarman (Yesterday)
Old Yesterday, 11:35 AM
Psycom's Avatar
BONUS??? 😆 🤣 😂 nooo, the headliner coming down just prior to finding the leaks was the bonus!!! Never a dull day.
I'll look closer and ck the power steering. The engine oil ... wonder if its related to the tensioners that were just done? Didn't have any least before that. A full inspection is scheduled next week.
Old Yesterday, 12:47 PM
xjack's Avatar
Headliner actually is a nice weekend project, and you can stick there any fabric you imagine and like, no more boring beige
Rear end leak have nothing to do with tensioners, perhaps you didn't spot it prior to the job but was there already
Old Yesterday, 01:50 PM
Received 8,178 Likes on 4,934 Posts
Thank you.
There is NO ATF colored RED compatible with a ZF 5HP24.
Old Yesterday, 07:04 PM
Psycom's Avatar
I was wondering about that. Thought I'd read zf fluid was a different color but can't recall what it was.
The power steering was over-filled but i couldn't find any traces of fluid anywhere. All I see is in the picture.
Oddly the last 2 days I've not had the gearbox fault or limp mode. I've been going through the gears before driving so maybe that helps.
Or
I have a car that needs Viagra.
Old Yesterday, 09:33 PM
Psycom's Avatar
I'm running outta weekends!! it looks like a lotta work taking out the head piece with many breakable parts along the way.. if I ever get ahead...
The oil leak or leaks yet to be identified. No sign of any source so fa. If I spot anything related to the tensioners the dealership will hear about it.
jekyllman
General Tech Help
01-26-2023 10:28 AM
galenmcallister
05-05-2021 10:58 AM
buttercup26
11-16-2013 06:00 PM
mjlaris
07-31-2012 06:53 AM
Quick Reply: Trans leak help identify pls
