Changing front crankshaft seal, what else should I do while it is apart?
I have a 2007 XK with almost 200k miles. The engine sounds great but had a really bad leak. I am in the process of changing my front crankshaft seal. I have radiator removed so I have complete access to the front of the engine. So I want to know what else I should do while it is open.
I have already changed valve cover gaskets and plan on changing oil pan gasket because I can see that someone was already poorly done it. I also am replacing driver side motor mount and flushing all fluids.
Received 2,062 Likes
The following 3 users liked this post by kj07xk:
McJag222 (08-25-2024)
Get the one piece water pump.
See this: https://www.jaguarforums.com/forum/x...0/#post2587348
Good luck
Good luck
The following 3 users liked this post by fritzthecat:
Lagonia
09-02-2016 07:33 PM
wotcham8
06-05-2013 03:24 PM
