F-Type Running lean, but stalling at idle.
I started my car up the other day and it was idling very weird. Revving up and down between 1-2 rpms. Started up again on my way home and the idling was even more dramatic. On my way home, codes threw off for system running lean on both banks of the engine. Took it home, cleared the codes, re-flashed the ECU with the original tune. On start up the idles immediately went from 2k to less than 1k, the engine began to stall out, giving it throttle kept it alive. At a glance the intake system seems fine, and i dont hear any leaks. These are the only codes i am getting. And honestly, I am leaning towards a clogged fuel filter. This has all come on very suddenly. This is because it simply feels like the engine is not getting enough fuel, and the issue has become more and more pronounced each time I start it, as if whatever is in the tank is making its way through the filter.
Was hoping someone could chime in. I suppose it could be the sensors, but again, im not getting any other codes besides system running lean on 1, and 2.
Received 2,682 Likes
dvsadam
12-31-2015 08:27 AM
