Hole for differential service. 2003?
Hey All
I've been going through my to-do list and next up is my differential oil change. What I'm trying to find out is can the hole in trunk method work for a 2003 Convertible? Have been searching and haven't come across anything definitive for this year/model. Most times I'm finding or coming across information on early x100s and coupes. I have absolutely no problem drilling a hole and plugging it when the service is done. As always thanks in advance
Cheers!
Andrew
Cheers!
Andrew
I'm sure the method would work but first I would check whether you need to use that method as you might have enough clearance without any drilling. It's worth investigating as you might need to drill through two sheets of steel which complicates the process a little. You will be able to determine that once you are under the car.
Richard
Richard
Evap canister huh? I thought I remember reading at some point there's a support brace in that area that can be in your way. Guess that's why I'm asking because I would hate to go through the process only to find I'm not able to access the plug or drain/fill easily. As far as the oil from what I've been reading is important due to compatibility, noise, etc... Search the old threads there should be tons of information on the best oils to use.
Many owners use a 75W - 90 or similar which would be fine. However, I use a 75W-140 as my extensive research many years ago suggested that this was closer to the original Shell spec.
Richard
cjd777 (08-30-2024)
Battling with the issue myself. Tried to get at it from underneath, which is a challenge, so even if you get the plug out (which I didn't get to yet), it'll be a pain to remove the old oil and re-fill. I then looked into drilling the hole, but with the later models there's indeed 2 sheets of metal to go through and there's a hose (evap?) in the way. However, once it's in and in the right location, changing the oil should be easier. I'm now leaning towards removing some of the stabiliser bars that are in the way underneath and get to it that way. There are videos for both ways on youtube. Either way sucks and how you do it comes down to what you hate less.
gregstar
05-25-2011 01:05 PM
390HPTypeR
02-21-2010 06:03 PM
