2011 XKR Convertible - broken lug, studs and tool for hub removal
I bought my 2011 XKR about a year ago and just had a service from my local European specialist in Charlotte NC. All good generally except when they tried to take off the wheel lug nut, a couple of the tops snapped on two of the wheels.
No immediate problem (the lug is secure etc) but I'm going to have to solve this when I want to change the tyres at some point.
So a couple of things:
2. If I can't use the above stud/lug then I gather I need to buy a whole new hub which comes with the studs. Assuming I go that route, I gather there is a "special tool" needed specifically for Jaguar to remove the bearing from the hub. Spoke to my local authorized Jaguar (Charlotte) and they didn't know what I was talking about. Anyone know what the special tool is... and where I can get one?Thanks all - always appreciate the great advise I see in this forum.
1. I am told they can't replace the studs (which will need to be drilled out) because Jaguar don't sell them anymore. No OEMs, but looking online I see aftermarkets like the following. Aren't those the same studs and lugs that would be needed?
Why are you fixing what your "local European specialist" just broke? That's their responsibility, not yours. I assume you also paid them in full to damage your XKR. If you did, and paid with a credit card, you can dispute that charge.
I'm sure that happened because some unqualified tire jockey used an air gun or similar power tool together with the wrong size socket, which spun on the outer shell of the OEM lug nut and deformed onto the inner solid nut. There are lots of threads about this on this Forum. If you need to remove a damaged OEM lug nut, simply take a 19mm deep socket and hammer it onto the damaged nut until it's secure, then use a hand wrench to remove it.
It appears that they broke the tops off of two studs. They should be able to source the same size replacements.
Take your XKR back to them. Write a memo documenting what happened in detail, and give it to the shop owner. If you start working on it yourself, you jeopardize your claim against them.
This was no accident. It was caused by their incompetence.
I understand your point, but to be fair I've seen a number of cars in the forum have a similar issue, especially when its spent most of life by the coast etc. My car (before me) was in California and Florida.
Also, when speaking to Jaguar authorized they seemed to be unsurprised by the issue, just less familiar on how to fix it (they don't cover cars over 10 years old)
Byte Me
07-09-2019 10:56 AM
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
