Tyre pressures?
motorcarman (Yesterday)
Received 1,692 Likes
I have the 18” double nickels also. With every tire brand I’ve tried I’ve had the best and most uniform tire wear by going to a midpoint between the two factory suggested tire pressures:
my midpoints:
Front : 29 psi
Rear: 31 psi
Otherwise the high published pressure will result in classic signs of overinflation (wear in center of tread). And the low pressure gives accelerated tread wear.
Z
jagatlast
22
10-09-2010 12:02 PM
