S Type R - removal of headlamp washer pop out ??
Theoretically - if I cut the stems off the pop out in the position marked to disable the washers, what would happen please?
Would the system loose pressure and stop the screen washers working too?
And yes, I know that a Xenon lamped car is supposed to have working washers as a MOT requirement etc.
Many thanks
Many thanks
One suggestion since I guess the bumper cover is messed up and you don't want to remove it? I "think" if you remove the front wheel well plastic liners you should be able to get access to the head light washer assemblies? Maybe not even remove them but unhook the front portions and bend the plastic liner back to grab the electrical plug on the head light washers?
Yea that's the problem with the fuse idea they usually operate multiple things in the car.
Hmm, it’s strange pulling fuse F11 (in the front power distribution box) also killed the wipers. I’m scratching my head over that.
One more thing you can try:
Remove relay R18 in the same panel. That sends power to the headlight washer pump and nowhere else.
If that doesn’t do the trick, I wonder if there were some wiring changes from year to year. Perhaps your car was close to the changeover and we are looking at the wrong year.
Edit: Just checked 2003 and 2005 wiring diagrams. For the headlight washers, the only difference I saw was F11 increased from 30 to 40 amps.
Beretta9 (09-17-2024)
I’m pretty sure the headlight washer assemblies do not have any electrical connections. I see a dedicated pump for the system, a fuse, and relay, but nothing near the nozzles.
When the pump runs, hydraulic pressure in the lines pushes the nozzles out to the extended position. It’s basically a piston in a cylinder. When the pump stops and pressure is removed, the nozzles are lightly spring-loaded to the retracted position.
Here is a picture of a nozzle assembly, shamelessly stolen from eBay:
I am still perplexed why pulling fuse F11 didn’t work. It only goes to the headlight washer relay and pump, and nowhere else.
One more thought, just in case your car’s wiring is somehow different:
Find the headlight washer pump and disconnect the electrical connector. No idea on the exact location, but you should be able to follow the lines back from the nozzle assemblies. If guessing, I’d imagine it’s near the fluid reservoir. Be careful not to unplug the other pump for the windshield washer.
I removed my r18 relay on my 03 v6 last year and it worked. I did this because the jet cover didnt line up properly and I would have to push it in to get it level. So rather then lose it one day I removed the relay and glued the cover. However I don’t have the xenon lights.
Luke
kr98664 (09-20-2024)
kansanbrit
07-26-2024 06:54 AM
Tony Murnion
07-29-2023 04:54 PM
