2000 vandon plus 4.0.
Hi everyone. Im from Louisiana 61 yo i have a 2000 vandon plus. Not sure if this is the right place to post for some help ? But it has a p1000 code. I kow what that code is but the car stumbles on hard acceleration. And at an ideal when you slowly bring r p ms up it stumbles. Fuel p s i at rail ie at ideal about 38 and about 45 wide open ck for vac leaks none found replace fuel filter If you drive it normal it seems to do ok. It has no other codes but the p1000. And the reduced performance and engine light is on Thinking it mite be the fuel psi regulator? Any thoughts thank you
Ronnie b (09-20-2024)
Received 4,047 Likes
Received 6,351 Likes
Welcome to Jaguar Forums Ronnie B,
Received 9,461 Likes
Received 4,330 Likes
