Rear clunking only when turning
Hello I have problem and I'm not sure what's wrong with the car I need to have an idea before I take the car to the mechanic . There's clunking sound in the rear end only when fully turning the car I believe it's only the right side
no noise when driving straight or even over bumps
rear shocks are billstein 1 year old changed with the donuts
Im not sure what's the cause of this sound
could it be wheel bearing Or something else?
Hangers first as the exhaust can be shifting to the outside , you may see some marks on the tire , there is a rearmost hanger at the rear bumper , quite a challenge on it's hardware as the pipes hook into the rubber
In my opinion 2nd check and cheapest , the wheel bearings and depending on the taper of the wheel bearing for which side
Whats good brand for the wheel bearings and how many bearing need to be changed since I will rebuild the rear end ? I honestly prefer aftermarket as the OEM very expensive or maybe not even available . Thanks
To map out your parts and their names
Search Genuine Steering And Suspension Parts For Jaguar Xj 1998 - 2003 (from 812317 To F59525) (x308) Classic | Jaguar Land Rover Classic Parts
and a bushing source
Jaguar XJ8, XJR, XJ Sport - X308 (1997-2003)1994 to 2002) Replacement Suspension Bushings (powerflexusa.com)
The bushings come in different densities and roll bar thickness bushing depending on your model , supercharged
How To Choose | PowerflexUSA
You can pour your own from a 2 part mix on the internet and some have done this
There are threads on the X300 and X308 section as they are very much the same
