Oil pressure switch
Oil pressure switch
Hi all, I am new to this forum after recently purchasing an xjr6 1997. I am not new to jags or the jag forum in general and also own an x100. Could someone help me with the oil pressure switch please. I have researched it and my original is numbered lna 5642 ca. I think this was replaced by jlm20791? Can anyone confirm this please. If this is correct any suggestions to where I might purchase a reasonably priced one or other options. As always thanks in advance for your help.
Ding
15-13 (jagrepair.com)
Your full list for the X300 here
Technical service bulletin
Thought I saw some oil pressure references in the past on the forum
separately from the oil pressure there is some stuff on leaking O - rings at the seperate block the oil filter screws into
Will be at dialysis and resurface in a couple of hours on chair
Parker 7 (09-21-2024)
Rock Auto has the part listed as ÜRO PARTSJLM20791
So ? is that an even higher version and reference ?
More Information for ÜRO PARTS JLM20791 (rockauto.com)
The oil pressure switch is in stock at British Parts
https://www.britishparts.co.uk/class...ssure-jlm20791
Also David Manners
https://jagspares.co.uk/oil-pressure...xjs-jlm20791-3
Also David Manners
TurboWood
10-28-2023 11:01 PM
jazzwineman
06-01-2017 10:37 AM
