Headlight/turn signal switch replacement
Has anyone changed out the headlight switch? My headlights periodically flicker and I think it's likely my headlight switch. Procured a new one and going to install, but came across this YouTube video that shows him reprogramming the module:
https://youtu.be/TvpigJsvlIk?si=BF1kAZrMAr4qviiO
I was thinking it would be just a straight swap and nothing else needs to be done - can someone confirm that this reprogramming is necessary?
My bet would be on an intermittent ground for the headlight assemblies. The switch is designed such that the CJB should be able to detect a failure (though perhaps not an intermittent.) It doesn’t switch the lights directly, the CJB reads the switch position by measuring its resistance. But surpringly (to me), both headlights share a common chassis ground.
The switch just has a series of resistors, so the CJB can detect the position, but also an open circuit.
Sage advise, thanks! I went ahead and bought another switch anyways to replace, but I'll probably try your suggestion first and see if it goes away. Thing is, it's intermittent and when it happens driving at night it's not fun! Still not sure based on that video if these units actually require some sort of coding when replacing them. I guess I could also try the new one and see what happens.
I was about to say no, I don’t know where it connects. But in looking for another document, I clicked on this, which does indeed show where it is. Ground G1D131B is located behind the box where you’d attach jumper cables, under the hood.
https://www.dropbox.com/scl/fi/a1wz9...=u41y1ltv&dl=0
The following 2 users liked this post by DJS:
bfrank1972 (Today),
Carbuff2 (Today)
Hmm, I was almost right. The first diagram I posted shows a common ground, but that’s for the adaptive/auto-leveling motors. The actual lights have separate grounds - the right one goes to that previously described G1D131 but the left one goes elsewhere, G1D129. So if both sides flicker together, it probably isn’t the ground.
