Jaguar Engine 4.2L XKE XJ6 XJ6C XK120 MK2 -Triple SU, High Perf, 250HP Turn Key
For Sale
Engine - Complete
  • Engine - Complete - Jaguar Engine 4.2L XKE XJ6 XJ6C XK120 MK2 -Triple SU, High Perf, 250HP Turn Key - Used - 1961 to 1971 Jaguar XKE - 1970 to 1987 Jaguar XJ6 - 1959 to 1970 Jaguar All Models - Oceanside, NY 11572, United States
XJsc-guy is online now
  • Price
    $9,975
  • Location Oceanside, NY, 11572, USA
  • Condition Used
  • Compatibility
Make Model Year
Jaguar XKE 1961 - 1971
Jaguar XJ6 1970 - 1987
Jaguar Any Model 1959 - 1970
Description:
Posting for a friend
For sale- Jaguar 4.2L 6 cylinder high performance engine for XJ6 XJ6C or XKE. Could also be used on XK120-140-150 or MK1/MK2. This engine is an absolute dream to drive and was built specifically for a near 100pt 1975 XJ6C no expense spared restoration. An extensive engine rebuild/upgrade was all done in the interest of improved performance for this fantastic car and the engine is conservatively rated at 250hp. It has been used sparingly over the last few years and has accumulated just barely 6000miles. TURN KEY-NEEDS NOTHING- this package is ready to drop into your car and fire up
Here are the engine specs:
Jaguar XJ6 4.2 bottom end (block/rods/crank) fully rebuilt all new bearings, gaskets, and seals
9.0:1 compression piston set
1970 XKE cylinder head
XKE Series 1 cam set
1967 XKE triple SU carburetor set, full rebuilt & rebushed with correct (and restored) linkage
Rebuilt and recurved distributor
Full XJ6 accessory drive- fresh alternator, power steering pump, and AC compressor with refinished brackets and hardware.
Fresh starter motor
This engine would be a FABULOUS addition to a true enthusiast Jaguar XJ6 or XKE project. I have conservatively estimated that it would cost  $25k+ to replicate this package if you started the scratch (a carb set like this, fully gone refurbished, with all components, would easily be $7500 by itself). With that in mind, the asking price here, all things considered, is a steal. The engine needs nothing- it is ready to installed in your car. Just bolt on your flywheel or flexplate, mate it to your transmission, and you’re on the road
For XJ (LHD) installations a custom free flow air cleaner assembly at no charge if desired.
The engine is  in Oceanside New York. We can assist with shipping if needed.....
If you would like to do an inspection in person, that is absolutely fine. Please contact me to set up an appointment.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
