Jaguar x type x200 Hi beam not working
My Xtype x200 high beam is not working. checked all the fuses and relays. all are working. changed the Light selector switch still same. replaced the bulbs with new. still both are not working. anyone have any idea about this issue. what should i check??
Themes1, you left off the last year of your car. Let me know what year your car is and I will look at the diagrams and give you a few checks to do so you can figure out what is wrong. The high beam circuit is not that complicated. Also, if you could, give me a general idaa of where you live (USA, UK, Far east, etc). This may change a few things as there are slight differences in the wiring for 3 different areas that have unique headlight requirements.
Thermes1, stick around. If you do some looking, you will find lots of useful information. People like me have built up quite the list of "how to fix" stuff for your car. It will make keeping the kitty purring a lot easier. You will also want to learn about the "Thermo'd rear arm". Your car is coming around to needing it. Solves a lot of issues.
Here is a list of model designations from Jaguar.
