Heater valve
Heater valve
Switched the heater to hot today and the heater valve started leaking (onto the exhaust producing a lot of steam!). If I switch back to cold the leaking stops. The water is coming from the valve housing. I guess it’s faulty but it looks very new. Anyone know law have a leaking valve?
https://www.sngbarratt.com/English/#...%20%60c9927%60
If you don't care about staying OE, there are plastic ones that cost little. There are also solenoid operated if you want to give up on adjusting the cable.
Anti-freeze: make sure you top up with the same colour. It's important not to mix different types. If Glyn is around, he will explain or Google one of his previous explanations.
