plug/socket disconnent
Starting to pull intake for hose replacement, looks like 120K miles+heat+previous mechanics have really taken a toll on many plastic connectors and plugs.
I'm trying to be 'gentle' and not break any more but for the life of me I cannot separate this assembly.
Does is simply pull apart or ?
Please help.
thank you.
wj
Please help.
thank you.
wj
I unclipped those a few weeks ago and can be a bit of a pig but it is a matter of jiggling apart whilst pressing down on something, but I can't remember which part exactly. On most of these connectors, including these, I use a small sharp right-angled pick to push or press down on the locking tab directly. If you examine it carefully you will spot which part needs to be "hooked" or "pressed" to release the bendy tab from the locking ramp.
I think there is another one on the other side of the intake manifold so try that one as well as it might be looser and you will then be able to see how the mechanism works.
Richard
Richard
