2007 XK jag door not close tightly with roof up, now battery completely dead
Old Yesterday | 11:09 AM
Smossbrit's Avatar
Default 2007 XK jag door not close tightly with roof up, now battery completely dead
Help - Please
2007 XK jag door not closing tightly with roof up, now battery completely dead, any idea what I can do?
Old Today | 03:21 PM
gmuirnz's Avatar
Use your emergency key (inside fob) to open left-hand door (remove cover from keyhole) or use key to open boot/trunk (keyhole probably hidden by number plate). Once in the boot/trunk you can access the battery to charge or change.
guy (Today)
Old Today | 03:27 PM
RichardS's Avatar
Or connect a battery or battery charger to the external +ve terminal which is aft of the rear wheel on the left-hand side.
Richard
guy (Today)
Old Today | 05:52 PM
kj07xk's Avatar
Yep, window drop doesn’t work without juice. After you charge the battery you need to do the window reset sequence.
Old Today | 08:34 PM
guy's Avatar
guy
but a completely dead battery typically means its replacement time.
Old Today | 08:50 PM
kj07xk's Avatar
Agreed. Should have just said that the car needs juice to run the window reset procedure, so the window drop will function and the door will close properly.
guy (Today)
dkucer
04-17-2024 07:33 PM
Don Fletcher
03-04-2021 07:37 PM
Abacusman
03-01-2021 07:29 AM
ferraripete
09-12-2016 09:02 AM
xkdreaming
05-30-2011 09:40 PM
Quick Reply: 2007 XK jag door not close tightly with roof up, now battery completely dead
