09 xf rear axle seal leak
no noise or clunking at all, I know the guy I bought it off had a shop replace it so after inspecting the work they did I'm hoping it was just incorrectly done.
I won't use them, just before I purchased it he said he had the oil pan gasket replace, I looked at it and it was leaking so I told him go get it fixed at a different place before I purchase it. I just Know that the 09 had that issuse with the contaminated diff oil from factory and how it would cause the bearing to wear out the aluminum housing. I'm getting it on hoist next next week, hopfully there is no play in the axle, this will mean the diffrence of either replacing the gasket hopefully or having to source a used one from the uk.
sense you mention this, ya you would think it would of been on its way out along time ago. Guess I'll find out this week.
Your right it was a big deal at one time but that has faded with time and I assumed (Dangerous I know!) they have all failed by now?
Kinda like the Nickasil cylinder linings on the old 4.0L V-8. Yes it was a big problem but after the engines either failed or were fixed it's pretty much vanished at this point.
Hoping you just need a seal!
