Water in trunk under battery
The following 4 users liked this post by Flstfi:
The water is in the Battery Tray?
1. definitely water - no cracks in the battery case
2. possibly spilled when the battery was topped up
3. leaking body seam (wing to floor)
4. detached drain tube
5. missing / defective rubber grommet
6. missing battery Tray fixing bolt allowing water through
It is either the riveted seams left and right corner below window . Push on them with the thumb. . To clean up properly wipe of with alcool then use some silicone to seal.
or the water drain at the rear lights full of debris , water beeing stuck and entering through the seal into the boot. Carpet loosened lights unscrewed 3x 10mm unhook connectors inspect , clean up fit back in.
sunroof drains to the rear go down through the C pillar down past the trunk . If you take out the side carpet you csn see drain hoses in each upper rear corner
Thermite (08-09-2024)
