A few Jags from the Mad Dogs and Englishmen Show
Have to import most bits from the US via Sea freight, so takes a while but Air freight on the big bits is pretty expensive
I’ve already had the new engine installed
Jaguar XJR supercharged V8 !
apologies, I meant to post the above Pics on a thread I had previously started on my XJRF100!
maybe admin can move them to the correct thread ? ….sorry !
I'll have to look for the other thread, I'd love to see the motor install. What are you going to use for a transmission and rear end ratio?
And, you probably have all your suppliers lined up but after owning a few Ford pickups over the years, I've had pretty good luck with these people.
https://www.lmctruck.com/
International shipping must be a fun process!
I’m using the entire XJR Engine , gearbox, ECU and loom
Its all been in and had it running, back out for body repairs
I have a 3.25:1 ratio with LSD and that ratio with the truck tyre size equates to the same as the XJR
Using LMC for most things , but I have to send parts to a shipping company and sea freight them else it’s mega bucks !
Apologies again for hijacking’s your Thread by accident !
david f100 (07-19-2023)
theres more on this build here ….
https://www.ford-trucks.com/forums/1...onversion.html
David Lagonda (08-02-2023)
