Any mobile mechanics in North West ?
Andy,
Can't help with local knowledge on mobile mechanics but it sounds like you're stuck.
A checklist for non-start issues on the 3.2 may help. If the engine is turning over the it's got to be electrics or fuel:
ELECTRICAL - check the following harness connectors are clean and dry:
1. multiplugs (1 x black + 1 x white) behind the RH headlamps - you'll see them from inside the engine bay
2. CPS connector
3. Distributor connector
4. MAF connector
FUEL
1. Fuel pump relay - temporarily substitute heated rear window relay
2. CPS connector
4. MAF connector
FUEL
HurQleys
05-02-2016 01:25 PM
Harry Dredge
05-01-2016 07:23 PM
